I didn't look too hard, but found nothing. I am correct to say the lug spacing on a 99-00 Prot is 4 x 100?
lug spacing.. 4 x 100?
yes it does. wrong offset and youll be sticking out of rubbing on the struts. i dont know the correct offset for your gen i know on first gen pro's 38mm is perfect.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
you have to look at the width of a rim when compared to stock. for instance a 6 inch wide rim with a 50 mm offset has a back spacing of of about 4.9607 inches but a 7 inch wide rim with a offset of 50 mm has a back space of about ... 5.4607 so about a half inch more in the back and half inch more in the front obviously. but i believe most of our cars came with 5.5 inch wide rims. and most of your aftermarket wheels in 16 or 17 inch are 7 inches. thus at stock offset you would need 3/4 of an inch between the strut and wheel on your stock wheels and 3/4 of an inch between the fender line and your stock wheel.
you can find out what will fit with a good accurate digital caliper and a little bit of math.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
