hey this is for a 2000 protege and i need to pull off the driver side front door to get at a nasty dent. has anyone done this before and if so could you do a little walkthrough on doing this for me.
thanks in advance
You'll need to pull the front fender off first I believe to get at the bolts that hold the hinge to the frame. After that it is just a matter of disconnecting the wiring harness, knocking out the pin for the bar that keeps the door open, and unbolting the hinges.
