Rally Armor Mud Flaps
    So I have Rally Armor mud flaps that I want to install on my car but I am unsure of what kind of screw or bolt to use. Help? They are the Universal Mud Flaps. Thanks.
    Use a self tapping screw with a large, flat head. The larger the head, the more it will resist tearing through if the flaps catch anything. It also requires no drilling as the screw is equipped with a sort of built in drill bit.
    Current:
    68 Torino GT Fastback
    86 MR2
    91 F150
    94 Escort Wagon BP swap
    99 Escort Wagon BP swap
    00 Miata LS
    08 Arrow AX8
    14 Mazda5
      I found one with a large head and also used washers to spread the load. One other problem I run into is on the driver's side, there is a plastic plate cover what I assume as components to my fuel system. With this plate on, the rear mudflap will not work. Any ideas on what to do?
ID:	1238691Click image for larger version
ID:	1238692I have finally finished with all of the mudflaps, what do you think?Click image for larger version
ID:	1238689Click image for larger version
