Speedo inop when cold!
    . . . . I have a 2002 Protege DX with Manual Trans and 2.0L Engine. Last winter the Speedometer became inoperative when the car was cold. In OAT above 50F the Speedo worked normally. Between 20-50F the Speedo would not work until after I had been driving the car for a while. From 0-20F it would take a long time to start working. Below 0F it never works. All summer it works fine.
    . . . . This winter I decided enough is enough. I got a new Speed Sensor(SS) and had my shop replace it for me. That afternoon I headed out to Madison and Milwaukee and it worked fine. Yeah! It is fixed. Not!! The following day I drove the car and the Speedo was again inoperative. After driving for a while it started working again as before.
    . . . . I got a wiring diagram from my shop and I saw that the Speed Sensor Signal goes to the Instrument Cluster(IC). The SS is a small generator putting out a square wave. There are two connections from the IC to the PCM. I thought that the problem must be in the IC. My DX came with no Tachometer. I found a IC with a Tachometer with just 1K more miles than my IC. I bought it and it is plug and play. Everything works except that I still have my original problem.
    . . . . The Speedo still doesn't work when the car is cold. I dug through the car until I found the PCM. The internet said it was located in various locations. Mazda said that it was located on the firewall on the right side in the engine compartment. I found it under the passenger carpet under the passengers front feet.
    . . . . I brought the PCM in and I let it warm up for a few hours. I then reinstalled it and the Speedo still doesn't work. Any ideas anyone? Could it be the PCM? I know that the PCM uses the SS Signal for fuel cut and cruise control. The vehicle has never been submerged and there is no sign that critters have ever set up house keeping.
    GOD Bless and Thanks,
    rich!
    Well the speedo is electronically controlled and it has speed sensors at the Axle. I'd think that one of the sensors is broken.
    "Who Dey"
      The speed sensor for my speedo is mounted in the transmission. My car doesn't have ABS. Please read the complete thread next time. There is a loose connection someplace but I can't find it.
      rich!
        sounds kind of silly. but did you check the connector at the speedo sensor? i've seen a few failures from intermittent connections there. perhaps that or corrosion are causing you grief
