this is mainly just a curiosity, like i was just wandering cuz recently i installed aftermarket CAI..... and i didnt reset the ecu(unplug battery for a while) cuz i was too lazy and i still havent so how much of a difference will it make when i get around to doing that? like 3-5hp? or... nothing?
re-setting ecu?
Does anyone know if i reset my ecu in this way will i need to recode my remote central locking (factory system), i work for audi and i know that if you were to do this on an audi you have to take ur car back to the dealer so your central locking can be re-coded. thanks guys.Pioneer 7650 HU
2x Pioneer 10" subs
Pioneer 2 way 5x7's
Pioneer 3 way 6"
Pioneer 4 x 100 WRMS amp
Pioneer 2 x 100 WRMS amp
alright, i reset my ecu after adding new spark plugs and messing with my intake and now the car wont start. what i did was i disconnected the negative wire for like 15 mins went back out and did the resetting of the ecu by turn the key and holding the break for 10 seconds and it wont start when i reconnect the wires. when i mess with the battery wires (taking them off, resetting the ecu over again) and i try starting the car itll work but every other time i try to start my car, it wont start and i have to mess with the wires again to start the car. what is the cure for this problem?Last edited by dafoo21; 07-11-2005, 07:22 PM.
Originally posted by jurgs01Uhhh... are your cables connected tight? Is there an excessive amount of corrosion? Do you have an alarm system with an ignition disable switch?
Depends on how old your battery is. You can clean your terminals, but I would recommend getting new connectors to crimp on your cables. They also have pads that come with new batteries that supposedly prevent corrosion. At the very least wire brush everything off (with battery disconnected of course).
