I'm looking at getting a 2000 protege with the 1.6L and it has an auto tranny and I was just wondering how reliable these cars are? I have a 91 Protege DX and it's fantastic so i'm hoping for the same with this newer one.
2000 protege any good?
Assuming the car is in overall good shape, properly maintained, etc., the 1.6 L should be a reliable car. However, with the AT it will tend to be a bit sluggish performance-wise. If you do acquire it, changing all fluids to syntherics, replacing the spark plug wires with NGKs, and the spark plugs with NGKs or Densos will get you off to a good start.
