Hey everyone. New member here. Great site.
I've replaced all my motor mounts but the rear and I'm stuck on dropping the subframe to gain access to the mount's bolts. The 17mm nuts on the long bolts coming down from the upper subframe connection in the wheel wheels are pretty tight and I don't have a metal pipe with a diameter large enough to fit my wrench into to get extra leverage. Those nuts were removed 3 years ago when the dealership replaced the rear mount, so it hasn't been too long since they've been cracked (vs 12 years of freezing up). Before I go down the path of getting a larger pipe or a sepcial socket, I'd like your help on the rest of the subframe work to make sure it's worth proceeding.
I'm not sure which other subframe bolts to loosen or remove. On the control arms, is it just the two outer bolts, where one also connects a bracket over the arm bushing? or is it just the one outer bolt that doesn't connect the bushing bracket? I'd like to avoid removing control arm bolts to the point of the bushing popping out. Not a huge deal, but I've replaced the control arms before it was a minor pain getting the bushing and holes to line up.
Do I need to loosen or remove the two front bolts at the front of the car that attach the long bracket to the subframe? This is the same bracket that supports the front engine mount. If so, I'm guessing I need to loosen the two bolts holding that front mount so that the subframe can drop with that bracket attached.
Regarding loosen vs removal, is it enough to just loosen and let the subframe drop, or do I need to fully remove the bolts and support the subframe with jacks? If jacks are needed, it looks like I may need one for each side, or is there a support point in the middle, such as where that cross bracket connects? I've only got one floor jack and would like to avoid getting another.
Detailed, I know. I'm just pressed for time and trying to avoid complications. But I'd like to save $200 or $300 and do it myself, especially since I'm guessing I may need to do this again one day. I'll be keeping the car another 8 years, and the last mounts lasted only 20k miles, either due to the idle issues I'd had but didn't resolve back then (because I thought it was just the blown mounts causing the rough idle) or that I used beck/arnley mounts, which I've used again without thinking they could be the cause (until now, dooh!). But I have resolve dmy rough idle issues, so hopefully these will last longer.
I also had a habit of shifting into park at lights because I hate holding the brake in rush hour, but I hadn't realized that a tranverse front drive design rolls the engine back so much when shifting between park and drive, so maybe that contributed to the wear.
I'm no expert mechanic, but I've done on lot on various cars over the last 30+ years, so I know if I spend enough time on it I can do it myself. The key is reducing time and complications with more knowledge, so any help is greatly appreciated!
PS: I don't have a shop manual like my other vehicles, so if anyone knows where I can down load one (preferrably free), I'd be grateful.
Cheers
Cheers
