I'm getting a vibration at idle that only occurs when the AC is on, and not all the time when the AC is on. It intermittently comes and goes, in 5 to 15 second intervals. When it's not making the vibration, the car idles fine and at the right rpm. When the vibration starts, the idle speed jumps a little and I hear a fan like noise.
In all my years working on cars I've never dealt with AC issues, so any kind of fan related issue is new to me. Does one of the small fans in front of the radiator turn on when the thermostat hits a certain open point or the engine a certain temp? If so, shouldn't it maintain a consistent speed and not vibrate?
Searching the net I see references to fan relays, etc, but those appear to be related to the fan swicth inside the car, so I'm confused. Are they related? Is there a separate relay or resistor specific to one of those fans? If so, where is it located and would repacing it solve my issue?
I've sorted out most other rough idle issues recently:
1. Motor mounts. Big difference.
2. Idle Air Control Valve - A new one that fixed the rpm hunting issue I had, AC on or off.
3. EGR Valve - Had a non-cleanable sticking point in the middle of its travel (tried cleaning but didn't work), so a new one resolved the low idle speed issue I had.
4. Exhaust/Converter/Oxygen Sensors - Clogged exhaust overheated the cat. New exhaust and cat. Replaced the sensors because it's recommended and there's 97k miles on the car. Didn't seem to affect idle as much, but made a big difference in smoothness and acceleration once driving past idle.
5. New spark plus and wires. Minor improvement.
Thanks a bunch.
Thanks a bunch.
