Unable to solve oil leak on valve cover - 1.6 ZM
    The gasket is new.
    I leaks in the same spot, along the front of the engine, (bolt number 1 if you follow the manual) it may take 2 days to show up. I even used maf cleaner to clean all the surfaces, it was excellent clean on assembly.
    I have done the same operation 3 times.
    I even got the black rtv for the corners, thinking it was leaking from there.
    I torqued and retorque and nothing.
    So far, the only explanation I have seem is the oil itself, is 5W-30 Synthetic Mobil One. But not the brand, but being synthetic, I do not know if it is true but seems that synthetic oil tends to seep more than any other, it was I read.
ID:	1275391Click image for larger version
ID:	1275392Click image for larger version
ID:	1275393Click image for larger version
ID:	1275394Click image for larger version
    I was thinking of milling the valve cover maybe 1mm to see if I could tight the gasket more, but then I though about the cam sensor so no go there.
    Could it be that this brand new gasket is just bad?
    I fixed the leaking by doing two things:
    * Changed the oil from full synth to blend,
    * and using the real black rtv (the good, expensive one).
    Apparently the full synth (for this engine that has unknown maintenance) it was too much, so I must run blend a few times to clean the engine during the year before going full synth.
