What does it mean if my brake light come on and off when I press on the brakes hard or corner hard?
Brake light coming on?
Check your parking brake setup. It happened to me once.My MAM SS Kit Install Thread | Gauge Customization kit - LEDs, icons, more! Sample:
check the parking brake how? When I pull up on it it comes on and when I push it down it comes off and if i shake the e brake handle the light does not blink or anything. And now that it has gotten cold here lately the lights tays on the whole time I'm driving. What would cold weather have to do with it?2005 Velocity Red RX8 GT 6 Speed
My second 88' CRX HF Hybrid , gutted, mildly Built B16A + many extras.
Top off the brake fluid to full, see if it still happens. The light comes on when the "low" level sensor is activated. During high Gs (hehe) the fluid will slush around. Did you ever notice how the low fuel light can go on or off depending on if you're on a hill or if you brake hard? It's the same thing.
Also, this might be a sign your brakes are starting to get worn, as the fluid has to be pushed out further into the caliper to get the pads to contact the rotor.2006 Mazda 3 hatchback manual
BRIZAKE FLUID.........made mine calm down.......then i had changed the brakes and calipers....nice ride now!"mess with the mazda...... mess with the chick......."mazdachic"
I don't go looking for no trouble but somehow the trouble always finds me, Don't make me have you in the trauma center With your momma crying cause her only son is dying, She just don't know it's just your karma catching up cause I'm a Drama Setter
Wonder if the problem was solved??"mess with the mazda...... mess with the chick......."mazdachic"
