when adding even stiffer sway bars, you induce more rear wheel lift, not less. Unless you go uber crazy with sway bar sizes and spring rates
I still maintain that adding larger diameter stabilizer bars will reduce inside wheel lift while cornering. I base this both on my own personal experience and on the explanatory material contained in this reference:
Stabilizer bars are sometimes also called anti-sway bars or anti-roll bars. Find out how stabilizer bars keep a car's body from "rolling" in sharp turns.
02 DX Millenium Red
I still maintain that adding larger diameter stabilizer bars will reduce inside wheel lift while cornering. I base this both on my own personal experience and on the explanatory material contained in this reference: http://auto.howstuffworks.com/question432.htm
02 DX Millenium Red
reduce lift yes, eliminate it, no. It's still spring rate dependant.
