Should I replace the brake shoes
According to the FSM, the minimum brake lining thickness allowed is 1 mm (.03937"). Replace both left and right brake shoes if either lining is at, or less than, the minimum thickness.
The maximum allowable inner diameter of the drum is 201.5 mm (7.933"). Inspect the drum for scratches and uneven or abnormal wear and repair or replace the drum as necessary.
Thanks for the info :-), The drums are back on the car now but next weekend I will make the measurements and see.Originally posted by goldstar View PostAccording to the FSM, the minimum brake lining thickness allowed is 1 mm (.03937"). Replace both left and right brake shoes if either lining is at, or less than, the minimum thickness.
Happy Motoring!
Thanks for the reply :-) I have a feeling I will be replacing at least the shoes.Originally posted by SgtRauksauff View Postthey might be within tolerances, but they look like they're wearing slightly unevenly.
I'd put in new shoes, and get the drums turned, because you've got them off, and they're fairly inexpensive parts.
