i had to replace the trailing arm and lateral link on my 02 mazda protege SE. i need a new mount bolt, that runs thrrough both lateral link bars and the strut assembly. after browsing mazdaparts.com for FOREVER i gave up. I found the piece I need here, but its for a 626. not sure if theres a difference and they arent very specific about measurements and what not. any help? much thanks in advance.
Help Sourcing a part. (mount bolt)
Take a sample down to the local parts store. If they don't have it, they can probably refer to you someone who does. Bolt's don't have to be OEM as long as they meet the standards of the original.
Vancouver Bolt is my local supplier. I'm sure you have an equivalent.1991 Protege LX with GTX swap, DD1990 4WD Protege with GTX swap, Project/garage decoration2006 Mazda 3 with 2.3, Her car1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
Beater=/= Sleeper
Originally posted by activeradio View Postmuch obliged. hard to take the old bolt in and get a reasonable replacement, because its bent, mangled, and in about three pieces one of which is still stuck in the old lateral bar. needless to say it's been a busy day.
After working on mazdas since the 1980s... the one thing that makes me hate mazda and JIS fasteners in general is how easily they break.
Bolt Depot
If worse comes to worse, you could always make a trip to the j/y and pull one.1991 Protege LX with GTX swap, DD1990 4WD Protege with GTX swap, Project/garage decoration2006 Mazda 3 with 2.3, Her car1980 Ford F100 Short bed with 300ci 6 cylinder, work truck/home for moss
Larger than what? What model Protege is in the JY?
Hmm! Now you have me puzzled. I have an '02 DX and when I replaced my shocks with the heavy duty '03 MSP types, I don't recall that I had to change that bolt. However, it was a long time ago when I did that job.
