Are the rear drums self adjusting or is there a manual adjustment needed? I was reading some older posts on the subject but there was no conclusion. Here's why I ask:
My daughter's '02 DX has not been driven in about 2 1/2 months. When she pulled out yesterday, there was a slight noise from the driver rear as she backed out. Then, there was some grinding as she pulled away. It was quite noisy from inside the cabin, but not that loud from the outside. After a mile, she brought the car home. My wife said it sounded like something was dragging under the car (nothing is). I test drove the car, doing a series of stops, some slightly hard. Problem persists.
I watched the video on rear drum brakes (on an Escort) from the link in the older post mentioned above. I jacked the car up and confirmed that there was some noise and drag from the driver rear. I pulled the drum off and sprayed the drum and shoes with brake cleaner. There were no rust particles, small chunks, etc. There is however some drag, which sounds very similar to the noise from the video.
So, do I need to do some kind of manual adjustment to get rid of the drag? Do I just drive the vehicle as the author suggests and the noise will go away? If there is a manual adjustment needed, how is this done?
Thanks for your help!
