The later (OBDII) engines have a different wiring harness and require a different OEM connector - so it would not be a direct plug and play with our unit for now.
KL V6 engine Megasquirt Plug and Play released
Oh man, i will definately be getting one of these units over the summer time
1988 323 Station Wagon - KLG4 swapped
1988 323 GT - B6T Powered
2008 Ford Escape - Rollover Survivor
1990 Festiva - First Ever Completed KLZE swap (SOLD)
If no one from the future stops you from doing it, how bad of a decision can it really be?
well i wont be using the same harness. ill be using the KDLE engine harness. Im just not sure if i can use the coil pack with that. I know you said you are waiting to hear about adding coil pack functionality1994 Escort LX Wagon
2013 Hyundai Veloster Turbo
91 Infiniti M30 Convertible - Traded in for Veloster
91 EGT - Junked May 2012
"Going to church doesn't make you a Christian like standing in a garage doesn't make you a car."
"I usually downshift when I'm near a Prius so they can hear me hurting the environment"
oh ok that works. I know you say these are for off road use, but would anyone actually know if it were being used? Im assuming a map can be tuned to be very environmentally friendly for emissions purposes.1994 Escort LX Wagon
keeping my eye on this91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by MATT91GT View Postoh ok that works. I know you say these are for off road use, but would anyone actually know if it were being used? Im assuming a map can be tuned to be very environmentally friendly for emissions purposes.
Hey Lex my old kf69 ecu in my euro-spec 323 2.0 (KF-DE) V6 is blown away yesterday... since iam thinking about megasquirt my KF for a while i google'd a bit today and found this thread... as said in another german forum the wireing of the kf and k8 should be the same... did the Stratified k8 pnp ms will work on the kf too? perhaps with a bit finetune on the fuelmap? and the most important question: can it be shipped to germany in a week ?
greetings from berlin
Originally posted by xralmar View PostHey Lex my old kf69 ecu in my euro-spec 323 2.0 (KF-DE) V6 is blown away yesterday... since iam thinking about megasquirt my KF for a while i google'd a bit today and found this thread... as said in another german forum the wireing of the kf and k8 should be the same... did the Stratified k8 pnp ms will work on the kf too? perhaps with a bit finetune on the fuelmap? and the most important question: can it be shipped to germany in a week ?
It takes up to 7 days to build the unit and then another 1+ week to ship to Europe unfortunately so it will not be in your hands in 1 week. In terms of compatibility, I can't say for certain since we do not have this vehicle here to test on. However if the K8 (and KLDE and KLZE) for that matter have identical wiring then it will work. The K8 and KL engines from 92-95 have identical wiring.
