i could measure up the rack on my 91 escort gt... 99% sure its identical to the BG protege lx
4WD Steering rack
I have an extra 4wd rack, but it's rhd so you probably didn't want it anyway.1990 Protege 4WD
1 3 5
2 4 R
i bet if you disassembled it you could use the pinion and rack in a LHD housingEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Possibly. My rack is okay though, so it's up for grabs.1990 Protege 4WD
1 3 5
2 4 R
i have a gt-r 4WD steering rack spare, LHD.
it came from a good running car (fat rear damage beyond repair), if i remember correctly one of the boots has to be changed as for transport damage.
if you'd like i could make some pics, shipping would be possible.
the gt-r racks have a different gear ratio, they are more direct
powerEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
I'm kind of wondering myself, is the BG GTX RHD rack a different ratio than the LHD BG Protege 4WD? I was going to take apart my AWD rack at one point to see if I could get a better ratio in one of my FWD cars, but I've got an MX3 rack insead, so haven't taken it apart yet.
maybe in a couple of weeks..
--sarge
Pretty sure it's the same.1990 Protege 4WD
1 3 5
2 4 R
