I have come up with a plan...correct me or change anything you dont think would work. Ok...half chassis the front, make a custom tranny tunnel, awd rear diff, awd cvs, fuel cell in the place of the spare tire, either 13bt or kzle w/ rx7 tranny. The main question left is the steering rack. Any ideas?
rwd protege conversion?
If you're gonna go through all that crap, don't bother with the mazda rear end. I've sheared the teeth off of two gpA rear diffs. You don't need to worry about matching up final drive ratio or anything like that and since you're making a complete custom subrame, making it to accept (insert stout rear diff here) is peanuts compared the the rest of the worklist you put up. I looked at how much trans tunnel mod was needed and decided that it was asking too much of a thinguage unibody, even with a full cage. Tread lightly. Never did figure out what to do about the rack either, though I didn't really put much effort in on that problem.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
and just think jay, your steering rack is set up even higher than the rack in a fwd protege.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Nuthin a hole through the bellhousing and a flexible input shaft wouldn't fix :p'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
IIRC setting it higher makes the problem worse. Only way to be sure is to start measuring sh@t up.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
If you're putting in a custom subframe for a RWD car... mount the rack on the front side of the frame, and swap knuckles from left to right, which'll put the steering ears forward. You'll obviously have to fab up something in the steering column anyway. Just go to a JY and look at other RWD cars and see how they're set up. A miata or RX7, if you want to stick with mazda...
--sarge
Let's see a show of hands for how many here have converted a fwd protege to rwd, and thus would know whatall would be needed to run a sooby steering rack with reversed hubs.
I'll wait...
hmm.
I think in order to answer those questions, you are going to have to find out by blazing a trail.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
Not to be a nay sayer... but if you have to ask that question... this might not be a project for you.
1988 White GTX - #1 parts
1988 White GTX - #5 Rally car
I should not be encouraging you, but I can't help myself LOL
My idea:
Buy a cheap last gen RX-7 (right hand drive ones go for peanuts) cut the whole body off it and sell all the body panels. Sell all the mechanical parts off the protege too. Then cut the floor out of the protege and weld the protege body to the RX-7 floor. It sounds extreme. But in my other Scene (Mustangs) This is actually becoming quite common place. I have seen this done with 60's Mustangs. They weld a 60's Mustang body to the floor of a late model Mustang or T-bird floor. That way it will look like a protege but will have all the factory engineering work done for you (by the pros). Just remember to measure 100 times and cut once. Not sure what a RX-7 wheel base is, If it is exact, plunk it on. If it is close modify the wheel wells with bolt or bond on flares. If it is apples and oranges the floor could be shortened or lengthened to match.
Proof of concept: A 65? Mustang on a Miata! LOL
Am I going to hell nowDominic Toretto rocks a MaZda and his cell phone number starts in "(323)"
idk the rx7's have a longgggg hoodEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
http://www.youtube.com/watch?v=e0f4mGY72Y8
^^^This guy Stefan, used a miata trans and rear end for his rwd Escort GT. You should be able to do the same with a protege.Before you criticize someone, first try walking a mile in their shoes. Because then you'll be a mile away, and you'll have their shoes...
