GTR spindles wont work on FWD. You need an MX6/626 spindle with a GTR hub. Then, run this with Mazda 6 or MS6 rotors and calipers and you're there. Or use Protege 5 spindles/hubs with Mazda6/MS6 brakes. The difference would be that protege 5 uses much smaller bearings than the MX6/626.
GTR brakes
Originally posted by 323driver View PostGTR spindles wont work on FWD. You need an MX6/626 spindle with a GTR hub. Then, run this with Mazda 6 or MS6 rotors and calipers and you're there. Or use Protege 5 spindles/hubs with Mazda6/MS6 brakes. The difference would be that protege 5 uses much smaller bearings than the MX6/626.
P5 shares the same bearing as the BGEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
what about the bigger miata front rotors? or maybe corrado? idkEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i'd love to convert to 5 lug, except at some point i want 13" lenso drag wheels and they only come in 4x100Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i never said anything about going bigger, just going 5 lug lolEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Sorry for the post in a old thread... Just a quick note: I recently replaced the front hub bearing in my 90 gtx and it also uses the 74mm outer race bearing that the gtr uses. I believe the normal fwd bg uses a 70mm outer race. The package that the bearing came in stated 90-94 323 awd and 99+ 323. Hear the P5 is known as 323F. There is no such thing as a protege here. But all this got me thinking, when the bearing is the same for the awd and the later 323's, I can simply replace the hubs with the 99+ 5lug. I just need to get 4 for the front. But I'd need to put them in my hand first and take some measurements. But than I'm still stuck using the bg calipers. Maybe I'll just try to find gtr parts.Too bad I have AWD and you don't!
Jay, how do I go about ordering these pads you speak of? I cant find em online. Thanks!Ian Boyd- Bellingham, WA (click vehicle to view)
1988 BF GTX
1990 x2 BG AWD Protege
1991 Escort GT- SOLD
2005 Corolla
Call porterfield asnd ask them for my pattern, or maybe by thier hand-written label, 'sumitomo .15"'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
