i have a 90 bg FF and i want to make it into an awd ive search dang near the whole site to see if any one has done it
BG awd swap question
Prolly not. You'd need to put the car on a rotisserie and weld in a new trans tunnel, make a new rear subframe, find a saddlebag awd gas tank, etc etc etc.'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
if u want awd, id just buy an awd car or shell and build onto it.. be hella lot cheaper than tryin to mod a non-awd car into one. lol1993 Ford Escort GT-T
1992 Mazda Mx3 GS((Parting Out))
1994 Honda Integra LsVtec-Sold
1984 Toyota Corolla SR5-Sold
1983 Ford Ranger-Sold
My Turbo Escort GT build thread
My HUGE f/s thread. Go buy!!!
Myspace yooo
I did an AWD swap in my BF Capri I was able to use the exhaust tunnel but there is no room for the exhaust and things dont sit quite as perfect as they do on a real AWD car. The tunnel on the BF GTX is doublewide to house the exhaust and driveshaft, i was able to hang the exhaust real low and to the side but it scrapes
Ended up having to use a fuel cell in the trunk
The BG might be a little different but chances are you will probably still have to cut/weld/fab a lot of stuff though.
build thread here http://www.wihandyman.com/forum/showthread.php?t=44431
-Rocketman1991 Capri XR2 "GTXR2" BPT AWD Bastardization/conversion
Creator of the B6T Rocketchip
www.werbatfik.com
Stop advertising it damn it!! If I don't get GTX #4, and Jay doesn't pick it up, I want it.
1988 White GTX - #1 parts
1988 White GTX - #5 Rally car
it sounds easy to "move stuff around" but once you truly start doing something you realize just how hard it is and not to mention $$$Originally posted by 90prtegehave you heard a yaris drive by you??? it says immmmmmmmmmmmmmmmmmmmmmmmgayyyyyyyyy!!!!Originally posted by TurproFk the family. Drugs and hookers take priority first
bpt323: broom break
CRZbrussian: that sux
CRZbrussian: get swifer wet
CRZbrussian: ****s aluminum
Neither the floorpan nor the firewall need to be changed. The driveshaft will shoot down the middle hump with just enough room for exhaust with a bit of ingenuity. The front subframe, however, will require significant modification to clear the carrier and the steering rack will need to be relocated. A BF or BG rear subframe will nearly bolt up if you're creative.
(Pay no attention to my 3" dump pipe)
-Kevin
-90 Miata 1- #80 CSP, '01 1.8L Swap w/ working VVT
-90 Miata 2 - $2005/6/7 Turbocharged GRM Challenger
-91 Tracer - $2008/9 AWD Converted Turbocharged Challenger
-94 MX3 - #8 Hong Norrth LeMons/Chumpcar Racer
-02.5 Protege5 - The Daily
