I'm going to pick up a BP today to use in the protege, and from what I've read the 4wd manual transmission is a G series correct? If so that means its the same basically as the FWD G series right?
The main question I have is I was reading the FSM and it said the 4wd flywheel is different then the sohc fwd flywhee, I'm assuming this is because it would be the same as a dohc flywheel? Or am I wrong? Is the trans and flywheel on the 4wd unique to the 4wd? Hope that makes any sense? Lol
Thanks for any info
Thanks for any info
