I recently used the sticky about the different speeker sizes and install kit numbers. Well it says that 5.25's fit all around. NOT!! I have 6.5's in the rear deck no problem. The fronts are a different story. Although I have 5.25's mounted there, they are definately NOT the correct size for the holes. The 5.25 is to small yet the 6.5 is too big. Do i have an oddball car or is the information incorrect.
Whats with the incorrect info???
<html>
</head>
<body>
<p>93' Classic Black DX SOHC in S. Florida<br>
<img src="http://bellsouthpwp.net/n/e/netwrk13/small%20ones/Front%20b.jpg" width="248" height="175"><img src="http://bellsouthpwp.net/n/e/netwrk13/small%20ones/Angle%20R.jpg" width="319" height="177"><br>
3" Air intake & Cone filter, 2" cat back with Ultra Flow muffler and
Monza resonator tip. Kenwood KDC-522 MP3 head unit, Kenwood KGC-9042 Digital 9
band Graphic EQ, Kenwood SR-901 SIRIUS satellite radio receiver. Audiobahn 10" dual 4Ohm aluminum cone sub wired
for 2Ohms, Audiobahn 5.25s" in front doors, 6.5s" in rear deck. Audiobahn A8000T
800w mono sub amp, Audiobahn A6004T 75x4, vinyl <br>
<br>
</p>
</body>
</html>Tags: None
you can get by with a little trimming of the metal like I did to get my 6 1/2's in the door (they were 6x8's). It may be a 6" hole in that year Protege.2001 ES (Featured at SoundDomain)
Pioneer/SoundStream/JBL/Coustic/Elemental Designs/Focal/
KnuKonceptz/Lightning Audio/SoundQuest/Tiff/
Gel America/Dynamo Deep Cycle Battery/
Groundkit
I wish I had known before investing in 5.25's that they were 6's. Of corse I'ts my own fault. I should know better than to trust anything I didn't verify myself. I guess at this point I must seek out a set of those 6" to 5.25" adapters. Does anyone know of anyplace on the web that sells em cheap?<html>
</head>
<body>
<br>
</p>
</body>
</html>
</head>
<body>
<br>
</p>
</body>
</html>
Email crutchfield's sales deptmnt. They have items not on their website and are usually around $10 or so for an adaptor.2001 ES (Featured at SoundDomain)
Groundkit
Kevin
bro, your car has the capability to fit a 6 1/2 inch speaker, the problem is, with our windows, there is 1 7/8ths inches worth of clearance behind the speaker, which sounds like what you're complaining about. my pioneer 6 1/2's fit flush without rubbing against the window, the 5 1/4 is very tiny. i had a pair of kenwood components (5 1/4's) i shoved in the front doors and they sounded like ass. double check on the sticky for mounting depth, however, 6 1/2 does fit all around. my suggestion to you is find a better speaker with a shallow mounting depth. by the way, i love your install, very nice .
peace
p.s. looking at crutchfield, as far as singles, the only speaker listed as being compatible with our front doors is a pair of kenwood's.. their ****, trust me
I've never liked Kenwood for speekers either. I have all Audiobahn speekers and the problem I ran into in the doors is the basket of the speeker was too big. amd wouldn't fit flush into the hole. I am stuck with the 5.25's at this point since I've had them in there for over a week. The chrome baskets show even the slightest scratches and I'm sure the place I bought them from would baulk at that. The 5.25's sound OK... but I know they'd sound better if they were more solidly mounted. If I don't have an easy bolt in fix by this week end than I guess the ol' jig saw's comin out to make some adapter rings!<html>
</head>
<body>
<br>
</p>
</body>
</html>
Originally posted by walight01
they are 6" speakers, problem is noone really makes a 6" speaker
Rockford Fosgate makes a REAL SIX. the part number is
FRC 3206U'02' Vivid Yellow P-5 / 5-Speed / MoonRoof / Rota Battles with Yokohama ES 100's 215/40/17 / Tinted Windows / Bosal Cat-Back / Injen CAI / B&M Short Throw Shifter/kartboy Bushings / Eibach Pro Kit and....oh yeah, and that BAD Ass flaming skull on the back quarter windows!
'02' Black Mica P-5 (wifes)
5-Speed / Tinted Windows / Polished Wheels
<IMG SRC="http://www.sirnuke.com/scull.jpg"></img>
www.sirnuke.com
Kevin
you know, this i know of, and this i haven't really thought about. we had some mounting issues with my friend's honda, we used the right size, just the basket was too large. i don't know where to point you honestly. i've heard polk made a component set that fit in our doors, but i guess custom fabrication is your only bet in this case, i have ****ty pioneer 2 ways in my front doors, and for the time i've had them in there (a year and a half), i haven't had ANY problems with them. the sound is something left to be desired though good luck bro
peace
Kevin
bro, just had to rewire my sound system and decided to get some new front speaks while i was at it.. and i'll tell you what, the 6.5 audiobahns (model AS62Q) wouldn't fit in the door, period.. we ended up surface mounting them onto the door panel by cutting out the opening needed (some of the door panel grille was NOT covered by the rim of the speaker) cut out a piece of abs plastic to go on the other side of the door panel and sunk the screws in through the door panel and the abs plastic. we then remounted the door panel and BAM, enough clearance, and sound AWESOME to boot! our door panels are NOT thick enough to support the mounting of a speaker.. and bear in mind, this is an 94 LX door panel. hope this helps a little bit
peace
