Originally posted by D323
My GTR swap thread
What exactly are you going to be doing to the bottom end?-------------------------
'91 LX
'03 Mazdaspeed Protege #235
Originally posted by Identity_XWhat exactly are you going to be doing to the bottom end?
Im thinking about sending it off to have the block cleaned/dipped and all the bearing clearances checked as well as getting the bottom end balanced etc...I also want to get the rods shotpeened. Something to that effect.2013 Dodge Dart Aero
Sounds like a good plan. Hope everything goes smooth!-------------------------
'91 LX
Originally posted by TheMANif you're doing a tear down, make sure you get a new OEM oil pump, oil pickup tube, and definately OEM head gasket!2013 Dodge Dart Aero
Originally posted by LexMarc, does the block look to have considerable wear/grime on it so that it requires all that work ... or are you just doing it as a safe measure?
Some goodies came in today!
ACT Clutch:
And the Greddy Profec E-01 Boost Controller/ E-Manage Programmer:
Wow the screen was way smaller than I expected. Here is a shot with a Bic lighter for comparison:
Ahhhh ****, instructions are in Japanese! lol
