Im making this my GTR swap progress thread. I'll try to keep updated with everything as I go along. For now I'll just include my shopping list and what I have purchased so far. I'll throw in some pictures too. Don't get too excited...I have a ways to go.
Tenative Shopping List:
GTR Motor pic1 pic2 pic3 pic4 pic5 pic6 pic7 pic8 pic9 pic10 pic11 pic12
VJ23 Manifold and Turbo pic1 pic2 pic3
GTR ECU (BP-C8)
GTR Harness
GTR VAF pic
RC 550cc Injectors
Greddy E-Manage with injector harness, boost harness , boost sensor, and ignition harness pic
Greddy Profec E-01 Boost Controller/E-Manage Programmer pic
ACT Clutch #Z62-HDSS pic
OBX FMIC 23x11.75x3 Bar and Plate design pic1 pic2
Walbro 255lph fuel pump (from 93 up RX 7)
Vishnu Performance Hi-Volume fuel rail (from a 1.8L miata)
Apexi Twin Chamber BOV pic
MSD blaster coil
Magnecor Spark Plug Wires
BEGi FMU
ARP Head Studs
ARP Main Cap Studs
AFCO N Series Racing Radiator pic
FAL Flexalite Low Profile Fan
Greddy Boost Gauge pic
Greddy EGT Gauge
Greddy Oil Pressure Gauge
Tripple Gauge Pod
2.5" Intercoller piping
Silicone Adaptors
3" exhaust
Magnaflow muffler #14834
Catco high flo cat
3" downpipe
Adjustable Cam Gears
Wiseco 9:1 Forged Turbo Pistons (+1mm bore to the block)
red = items I have
This is just a tenative list..I might not end up with everything listed.
Routine Maintenance Items
Water Pump
Timing Belt
Timing Belt Tensioner Spring
Altenator Belt
Powersteering Belt
Intake Manifold Gasket
Exhaust Manifold Gasket
Distributor O-ring
Cam Seals
Rear Main Seal
Oil Pump
Front Oil Seal
Fuel Injector Grommets
Fuel Injector O-rings
Distributor Cap
Distributor Rotor
Thermostat
Thermostat Gasket
O2 Sensor
Oil Filter
Valve Cover Gasket
PCV Valve
Head Gasket
Gaskets for turbo
Heater Core
Balljoints
Brakes
Air Filter
I think that's everything...Im sure I missed something tho. lol
I'll buy a headset which includes most of the items on that list. Everything is going to be replaced. I don't want anything blowing up because I was too cheap to replace this ****.
Links for my future reference:
http://www.diamondstarmotorsport.com.../e01manual.pdf *Profec E-01 English Instructions!!
http://www.prostreetonline.com/pso/p...sp?articleid=5 *E-01 Installation tips
http://www.emanageforums.com/forums/showthread.php?t=29 *E-Manage FAQ
GTR ECU (BP-C8)
GTR Harness
GTR VAF pic
RC 550cc Injectors
MSD blaster coil
BEGi FMU
ARP Head Studs
ARP Main Cap Studs
Greddy EGT Gauge
Tripple Gauge Pod
Silicone Adaptors
3" exhaust
Catco high flo cat
3" downpipe
red = items I have
Water Pump
Timing Belt
Altenator Belt
Powersteering Belt
Distributor O-ring
Cam Seals
Rear Main Seal
Oil Pump
Front Oil Seal
Distributor Cap
Distributor Rotor
Thermostat
Thermostat Gasket
O2 Sensor
Oil Filter
Valve Cover Gasket
PCV Valve
Head Gasket
Gaskets for turbo
Heater Core
Balljoints
Brakes
Air Filter
