i was doing some reading on the forums and finally found some pretty decent information. i was reading a thread and i saw that the awr motormounts fit both the 1.8 and a 1.6. doesnt this mean that say a 00 1.8 would fit a 99 1.6, physically?
1.6l to 1.8l fits!!??
you're talking an engine swap?My MAM SS Kit Install Thread | Gauge Customization kit - LEDs, icons, more! Sample:
Why wouldn't a 1.8 swap into a car that had a 1.6? The car itself is the same, you'd just need all the associated parts besides the engine. Mounts, tranny, ecu, etc etc.Clint/1999 "Sport20"
what about a 2.0 then?My MAM SS Kit Install Thread | Gauge Customization kit - LEDs, icons, more! Sample:
i wasn't asking about it, I was suggesting it. Just go straight to a 2.0. Get all you can out of it.My MAM SS Kit Install Thread | Gauge Customization kit - LEDs, icons, more! Sample:
Both are good engines. I'd rather have the 1.8...more rev happy than the slow revving 2.0.Clint/1999 "Sport20"
interesting. I hadn't heard that.My MAM SS Kit Install Thread | Gauge Customization kit - LEDs, icons, more! Sample:
Originally posted by Drackonnyeah from what i have read i would rather have a boosted 1.8 ... this idea is making me very excited if it can work ....My MAM SS Kit Install Thread | Gauge Customization kit - LEDs, icons, more! Sample:
Originally posted by D323200cc's more isnt that much larger than you would think.02 DX Millenium Red - The Penultimate Driving Machine
