hhhmmmm, gonna have to research that. I always thought of it as more of a piggy back to the existing ecu, just modding the fuel/air/timing and other performance minded areas, obtaining the max from the motor w/o physical mods.
Standalone Options??
eh... i posted this in the other of your double posts so here it is again....
how much boost do you need to run?
if you're using the gtr oem computer did you know that you have maps to 18psi.... that's a lot of hp and torque.
if you want more than that you are gonna spend money on injectors and a standalone. There are a lot of options - Haltech, Autronic, Motec, Microtech, AEM, jeez there's about a million different ems producers out there. I personally have the new Microtech LT10s.
None of these will manage your engine as well as the oem computer so I would suggest that you set your boost controller for 18psi first and see if it's what you're after before throwing money at a project that could be a waste of time....Don't forget the cost of dyno time with a standalone.Last edited by Stefan; 03-23-2005, 04:02 PM.
Originally posted by Stefaneh... i posted this in the other of your double posts so here it is again....
if i can get the $ for an e6x edis is my next goal00 dakota 4x4
90 crx si - ls/vtec
