Get a new walbro pump! **** a used pump, that is ****ing silly.
Doing my GTX swap on the 27th, checklist
Originally posted by jitb37if all else fails u can go to a parts store and dig up a 3kgtvr4/rx7TT Fuel pump. They carry those in stock. but there like 190$-230$. But the proege Fuel pump is like 160$. IF you got the 90-92 dx fuel pump barcket u can use those Fuel pumps without any modification to the mounting bracket. I fyou have the 93-94 than u wil lhave to modify the bracket a bit, and or bend some metal around..lol
255lh HV walbro kit was $116 shipped for my egt, looks the same for a protege.sigpic
92 240SX: KA/T25, nerd mobile
Originally posted by cablemircyoyo.. hit a bump in the road here...
the GTX TPS is 4 pin, the LX harness 3 pin.
use the LX Throttle body?
if that's the case, can i use the 1.6L B6 Throttle body for the DOHC?, at least to get me home? both are 3 pin.sigpic
Originally posted by elscotto80And those people have pinging problems.
Originally posted by jitb37i beg to differ, about 70% of the peeps with GTX dont have the Gtx ecu. the either are using a stand alone. or the na ECu with a AFC.
im not taking sides, just sharing what i know... but i have heard something like 90% or ping is unaudible, especially with a loud aftermarket exhaust, thus the reason for a knock sensor... so while many dont hear it im sure either they are running super pig rich or they are pinging some.. without proper wideband tuning with the afc im sure that hardly anyone can hit that fine line of little to no ping (at an unaudible level) and too rich... which is not fuel economy efficient and *if* your running a high flow cat or even a stock cat a rich condition will kill it since it is there to complete the buring of the hc's (unburnt fuel).
so i ask you
being patient and waiting for the opportunity to purchase a gtx ecu = 250 dollars
or
running your na ecu, killing your cat, risking destruction of motor (if pinging is a problem). possibly a 150-500 dollar problem
while reading posts like this i tend to open up a bit, infact just before reading this one i was trying to convince my buddy quickegt to just be patient and wait for a gtx ecu, but i have opened up and learned to except that an na ecu will do the trick in the time being... but its up to you if you really feel that your peticular motor can take the abuse so be it but if your questioning it at all id say better to be safe at 250 bucks than to be sorry at 500 and still not be safe, just be running again.There are no stupid questions, just stupid people.
Originally posted by cablemirccan i use the 1.6L B6 Throttle body for the DOHC N/A motor ?, at least to get me home? both are 3 pin.
you should buy new vavle cover gasket, distributor o-ring, oil pan gasket, change the rear main cranshaft seal ( its nof fun to remove the engine 2 day after the swap its done, hapen to me) its only 30$ cnd at mazda. new timing belt / water pump. that all i remember for now.
i'm runing the stock escort gt fuel pump at 10 psi and i made 164whp and 158 tq. but i'm ordering a walbro pump this week.
you should check into the apexi turbo time. its fun to have and you get a good a/f reading with that thing. mine cost 130$ cnd2012 Kia rio
2009 Nissan Frontier
1997 chaparral 180LE
well thanks Lex you have anserwer my qusetions about the swap im about to do i blew the motor in my 92 lx and i figer that if i have to buy an engine i might as well get a bpt from cork sport. so all i really need is a gtx ecu thats cool well hopefully i can get my baby on the road for like 1700 bucks02 msp clone gone but will never be forgotten
might as well swap over the injector haness and rail from your LX to the GTX and you have to do no splicing ... obviously keep the GTX injectors.
Remember that your stock LX clutch won't hold the power ... either get the GTX one or an ACT/SPEC.
Going turbo is not cheap. Either way you look at it, the maintenance is more expensive and you will have to fab up an intercooler and exhaust.
i heard you can run the 1.8 SOHC ECU, due to the fact the SOHC has a lower timing degree, and also doesn't have VICS. i've heard of some guys down in mexico running like 11 seconds with the N/A SOHC ECU. also what size are the GTX injectors? 330cc? the n/a are what? 270cc?
JACK-Jack
