Originally posted by Lex
Dyno Results
Originally posted by MazdaTGTSNothing, the boost stays there all the way. I think is because the boost controller that I have (Profec B). For me the best boost controller for our cars.
I must be doing something wrong .... Mine drops to 12 psi by redline and I dont know why.
Maybe it's a leak, maybe it's the stock EGT exhaust maybe it's the ebay boost controller.
It's bothering me.
Originally posted by LexI must be doing something wrong .... Mine drops to 12 psi by redline and I dont know why.
It's bothering me.
Originally posted by EscortNationI have 2.5" exhaust with no cat or resignator. also 2.5" intercooler piping. Still drops off at redline
i hit 10psi by 3500ish and at about 5k if i hit WOT i will hit 15psi and stay there till redline....i have done this on 2 vj20 turbos now so i know that the turbo does NOT "run out of breath" as some people seem to think it does....
the boost gauge in my sig is a real shot of mine...91 323 GTX @ 16psi, 5 speed || December 07 R.O.T.M.
More Information
Originally posted by redfoxi hit 10psi by 3500ish and at about 5k if i hit WOT i will hit 15psi and stay there till redline....i have done this on 2 vj20 turbos now so i know that the turbo does NOT "run out of breath" as some people seem to think it does....
The best GTX I have seen on a dyno was running 12psi. 230HP on a conservative dyno, and a flat 230lb/ft of torque from below 3000 to over 5000 rpm. With a decent tune, 12psi is all you need, any more just kills the turbo quicker.
I don't understand the obsession with trying to run small turbos at higher and higher levels of boost???? If you want to run a lot of boost, get something like a big T3/4 hybrid, those things thrive on boost...www.323gtx.co.uk
www.323gtr.net
