Originally posted by Lex
GTX motor cutting back at 4.5k
Originally posted by LexThe boost cut is built into the ECU, not the AFM! Once the AFM reads a certain value (on the 0-5 V potentiometer which it is), the ECU will assume it has reached too high a boost and cut out. That voltage value is based on the stock GTX vaf which just like any other vaf can be tuned by tightening or loosening the spring..
over boost is a calculation done by the ecu it uses the vaf AND the tps
i sujest you replace the VAF with a rx7 B series dont dick with the spring just put it on set plugs to a gap of .030 fill her up with premiem NOT av gas or Trick fuel these are high in lead and will kill your o2 sensor..
you also didnt go enuff into depth on why you tune the vaf or how to
to tune it correctly at idle with all accessories off you test the o2 sensor for .5 volts tune for .5 volts if its off.. but i sujest you do not do this until you have put in a brand new o2 sensor.
if you wanna get good milage replace it with a 3 wire
wire the sesor out put up like normal then ground one of the heater wires and put the other on a ignition source
oh and RTFM guysLast edited by jacobrussell; 12-22-2005, 03:43 AM.eat me
