Gtx ECU?
    Is there a part number for the piston, and should I replace them all or just the bad one? What would be some equivlent after market pistons?
    Originally posted by Shades
    You probably were running rich after you had detonation and caused some damage... when you have little compression in the other cylinders, the ecu may think that you just need more fuel.
    So what are you gonna do now?... you're gonna have to change that piston, and I don't think you can just buy one, unless you go the dealership.
      I would get 4 new ones, maybe from a n/a bp, it will give you a little more power than the gtx ones will because of compression.
      BP-05 Turbo-Sold
      2004 MK4 AWP Jetta GLI
        from a miata 10:1
          I'd replace all four... if you have some spare cash get some Wiseco 8.5:1 pistons or contact Flyin' Miata and get their 9:1 custom Wiseco's.
          Keep the bearings in order and in the right rod and the rods in the right cylinder. Or you can change the bearings but keep the rods in order.
          Member of MX-3.com
          "Do it ONCE, do it RIGHT!"
            Sorry its been taking so long, I will hope to have pictures this weekend.
              I need to buy a new engine, where is a good place on the west coast to get one? Thankx
                I have a set of GTX rods and pistons in great shape. If the rods are all you need to get the car back together PM me
                hello 4g63 nice to meet you
                  where is a good place to buy a gtx motor, or just the wire harness?
                    corksport
                      fritz360 - Were you running a GTX ECU or NA BP ECU when you detonated? Also, do you have an upgraded fuel pump?
                      Back in BG business.
                        I was running NA BP ECU, I took out my upgraded fuel pump. I was running to rich.
                          Do you know anywhere besides corksport?
                          Originally posted by escortkid
                          corksport
                            My wideband A/F gauge shows that the NA ECU runs super rich but leans out really fast at high RPMS. You might have been too lean especially running the stock fuel pump.
