I told yall its not hard at all. very very simpel and straight forward.. and in expensive.
323 v6 swap
now i got fuel to the engine and i was try to start it but it wold not start then i find out that i havent no sprak on the sparkplugs what is wrong then
i used the 4cyl fuse box i the engine bay just to try to start it
since i dont have the v6 one yet can that be problemLast edited by low and slow; 05-18-2006, 01:51 PM.
If I had to guess, I would say the culprit is the distributor. Make certain that the distributor is paired with the corrent ECU. It might also be helpful to check for codes, although I'm not sure how or if you can do that considering your ECU is not from the US. It may bring up cam sensor (distributor) or crank sensor (sensor next to the crank pulley).
now i have installed a hei modul but it wont start now eigther i installed it like this
http://www.wihandyman.com/wil/howto/hei/index.htm
whitout a external coil. any won have som ideas
