is there anyone out there who has installed a haltec engine management system on a BPT engine. I need some help. To be specific it is a haltec E6X.
engine management
This is for an E6K, but the X is basicly an updated version of the K.
Installing a Haltech E6K on your Mazda BP Motor
Preparing your motor prior to the install will take a little bit of time, but will be well worth it. Follow most of my instructions and you should be up and running in no time.
Factory Harness Removal (Optional)
Unplug the ECU and remove it from the vehicle. Clip all tie downs and unbolt all bolts holding any of the loom to the chassis. Pull the loom out from the engine bay through the firewall. This does not need to be done if you wish to keep cruise control or factory idle.
Note: Some wire colors may vary, I have tried to spot them all and note them but it may differ on your harness,
Haltech E6K Install Notes
Fuel Injectors
Batch Fire (Optional)
Batch fire is only for people who need to use the extra Digital Outputs on the E6K. This mode fires the two banks of injectors alternately, i.e. 1+2 fire, 3+4 fire. This in term is like waste-spark but with fuel. You will always be injecting 1 cylinder with un-needed fuel.
Haltech BP-Turbo
INJ-1 (LIGHT BLUE | +13.8V) Cylinder-1 (Yellow | WHITE / RED)
INJ-2 (BLUE / RED | +13.8V) Cylinder-3 (Yellow | WHITE / RED)
INJ-3 (GREEN / RED | +13.8V) Cylinder-4 (Y/B | WHITE / RED)
INJ-4 (PINK | +13.8V) Cylinder-2 (Y/B | WHITE / RED)
Sequential (Recommended)
Sequential injection allows fuel to be delivered to the engine at a time that produces best combustion. Since this time is different for each cylinder, sequential systems inject fuel at different engine angles for each cylinder. This means better gas mileage and smooth idle!
Haltech BP-Turbo
DIG-2 (WHITE / BLACK | +13.8V) Cylinder-3 (Yellow | WHITE / RED)
DIG-1 (BLUE | +13.8V) Cylinder-2 (Y/B | WHITE / RED)
Ignition / Distributor
Factory Ignition
When using the factory ignition setup the Ignition Setup to the following settings:
Trigger Input: Rising Edge
Trigger Output: Falling Edge
Fires on: Falling Edge
Constant Charge
Charge time is 3.0ms.
Haltech BP-Turbo
Trigger Input Harness Distributor Harness
Ground (BLACK) Ground (BLACK / LIGHT GREEN)
Trigger (YELLOW) Trigger (WHITE)
Home (GREEN) Home (YELLOW / BLUE)
+13.8V inj (RED) +13.8V inj (WHITE / RED)
Haltech BP-Turbo
Ignition Output Igniter | Coil
This can get tricky so follow along closely
Ignition Output (LIGHT GREEN) Igniter + (GREEN / WHITE)
Ground (BLACK) Igniter - (BLACK / ORANGE)
Condenser - (BLACK / ORANGE)
Igniter>Coil + (Merge YELLOW/BLUE)
Haltech BP-Turbo
This is for using the stock ECU harness and leaving the ignition circuit intact.
LIGHT GREEN (GREEN / WHITE)
Using an MSD 6A
Change the charge time to 1.0ms and the Firing Edge to Rising.
Haltech MSD
Ignition Output 6A
Ignition Output (LIGHT GREEN) Trigger (WHITE)
Factory Coil Blaster Coil
Coil + (YELLOW / BLUE) Coil + (Small ORANGE)
Coil - (BLACK / ORANGE) Coil - (Small BLACK)
External Sensors
Throttle Position Sensor
The factory GTX TPS can be used in place of the haltech sensor if you do not want to fabricate the appropriate mount, or do not have a “D” shaft type throttle body. The automatic transmission TPS from the Escort GT or Protégé LX will be the same.
Note: Each TPS sensor requires a different throttle body.
4-wire GTX (or Automatic) Haltech
+5 Volt (RED / GREEN) +5 Volt (ORANGE)
Throttle % (GREEN / WHITE) Throttle % (GREEN)
Ground (BLACK / BROWN) Ground (BLACK)
Idle Switch (RED / WHITE) Ground (BLACK)
Oxygen Sensor
If you are using the Haltech 4-wire o2 sensor or a standard 4-wire Bosch o2 sensor the following wiring diagram will suit you. To retain the use of the factory 4-wire o2 found on most GTX and N/A motors use the second diagram, you will need to retain your factory harness for this to work properly.
4-wire GM / Bosch Haltech
Heater + (WHITE) +13.8 V (GREY / RED)
O2 Signal (BLACK) o2 Signal (GREY)
O2 Ground (GREY) Ground (BLACK)
Heater - (WHITE) Ground (BLACK)
Factory 4-Wire Haltech
O2 Signal (RED / BLUE) O2 Signal (GREY)
Cooling Fan Relay
Be careful when hooking this up, always use a Ground to test this wire with the key on. If the fan comes on then it is ok to hookup the PWM to it. The settings for most cars are:
On Temp: 190
Off Temp: 180
*Using a 180F Thermostat.
Factory Wiring Haltech
Relay Ground (BLACK / GREEN) PWM 1 (VIOLET / WHITE)
Boost Control Solenoid
There are three parts to the solenoid, one is the wastegate inlet, one is the manifold pressure inlet and one is the breather. You may have to switch the wastegate and manifold lines according to which way you hook up the BCS wires. PWM Settings are:
Period: 33mhz.
Use Wastegate: MAP 1
Boost Cut: 12
Boost Solenoid Haltech
Solenoid + (RED) +13.8 V Power (RED)
Solenoid - (BLACK) PWM 2 (PINK / BLACK)
BAC Valve
The BAC valve works in conjunction with the ISC (Idle Speed Control) valve on this motor. From 0-104F the wax inside the ISC starts to melt allowing more air into the manifold. There are two settings to this and they vary for every car, they are below:
Input/Output
Idle Speed Control: DISABLED
Target Idle Speed: 1000
Cold-Idle Up: 200
Start RPM: 200
Number of Steps: 100
Cold Temp Limit: 104F
Cold Min Pos: 78 *varies
Hot Min Pos: 77 *varies
Cold Open: 10
Hot Open: 20
PWM 3
Period: 10ms.
BAC Valve Haltech
BAC + (WHITE / RED) +13.8 V Power (RED)
BAC - (BLUE / ORANGE) PWM 3 (BLUE / GREEN)
