Originally posted by Faramire
View Post
Hi, about that v6 or v8 engine swap...
Originally posted by Jho View Post**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
well if you swap the DOHC motor into the protege with the stock auto transmission... you;ll soon be looking for a replacement transmission haha
i would say just hunt down a new trans for the escort. you could even swap the DOHC to the protege, with your new 5 speed trans, if you prefer the pro to the escort
SOHC is 108 hp i believe and DOHC is 125/127 depending if you look at the Protege LX or EGT specs! Essentially when the power drops of the SOHC at higher revs the VICS and extra valves help it along for a bit longer!**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
Originally posted by Tazman2 View PostSOHC is 108 hp i believe and DOHC is 125/127 depending if you look at the Protege LX or EGT specs! Essentially when the power drops of the SOHC at higher revs the VICS and extra valves help it along for a bit longer!
Originally posted by Jho View Post......And while the BP doesn't seem like is has that much more power just by looking at the numbers, it is an EXCELLENT platform to build from, unlike the limited SOHC.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by therieldeal View Postexactly. dont forget that the block itself on the GTR rally cars is exactly the same as on your stock BP. find me a honda boy who can say that about his motor**SOLD** 93 EGT with more suspension mods then your average riced out civic's # of decals + useless "bling/style/culture" mods! **SOLD**
wait he has a sohc escort right? so umm 88 hp if its a 1.9 110 if its a 2.0 split port.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
and uh ya car does not look lowered at all... if your rubbing your offset has got to be screwed. i have about 1 inch front fender gap and like no rear fender gap on my egt and no rub.mods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
yep checked he has 88 hpmods: engine: fm stroker lightened and knifedged crank, 11:1, custom crank scraper, fully p&p head and intake mani, bored throttle body, flowed and matched stock injectors, rx7 vaf, apexi safc, gude race cams, modded ecu 8200 fuel cutoff, blaster coil, clutchmasters stage 3 clutch, fidanza fly wheel and timeing gears, msp diff, custom shortram in a cold air box
