i ran into alittle problem with my fuel injector wiring, I'm using the SOHC injector harness on my BP injectors and there was a green plug on top of the SOHC intake manifold, the only green plug that I saw on my BP was on the right side of the engine below the distibutor in the center of the engine, is this the same green plug that was on the SOHC intake manifold, plz help, i don't know where this is soposed to be plugged into, thanks
SOHC wiring< to a BP05 engine
Originally posted by Mazda1320 View Posti ran into alittle problem with my fuel injector wiring, I'm using the SOHC injector harness on my BP injectors and there was a green plug on top of the SOHC intake manifold, the only green plug that I saw on my BP was on the right side of the engine below the distibutor in the center of the engine, is this the same green plug that was on the SOHC intake manifold, plz help, i don't know where this is soposed to be plugged into, thanks
No big deal
yes just two wires
the ecu is inside the center console/dash... up against the firewall on the center tunnel.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
