What years millenia? There's a 96 at the jy, and I've been wanting to pull the motor for some time, if it was the right one. (too many variations of the kl make my head swim to identify the right one).
FE3 vs KLDE
I know your stance Clint. Lol. You're the guy at the party "have a beer. Just 1. Come on. Pussy." "Ok just 1 though" "here have another" lol peer pressure mofo.
I've decided that whatever swap I do will not get done till I get a house and a beater so I have time to do the **** the right way the first time. I'm leaning towards the de swap though. Just for easy and more access to parts.1993 Protege LX-Midnight's shadow SOLD
not all millenia motors have ZE heads just as a warning---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Postnot all millenia motors have ZE heads just as a warning93 Escort Wagon V6-SOLD
91 Escort Wagon V6-SOLD
93 Escort Gt V6-SOLD
90 Mazda 323 SE V6-SOLD
93 Ford Ranger Splash-Its Baywatch time
ive seen 2 millenia KLs that were not KL31 heads. just keep ur eye out you'll see what i mean---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
might be replacement engines in them ryan. all millenias come with a de-tuned KLZE.
JACK.-Jack
im telling ya they didnt, how come no one listens---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by escortluver19 View Postwtf is a kl08? Ive never heard of such a thing, and ive messed with the v6 for a good while now.These are your motor options:
KLDE/KL03=usdm probe 2.5L(de heads, cams,intake,9.2:1 compression) 164hp
KLZE=jdm 2.5L(ze heads,KL31 cams,ze intake, 10.2:1 compression) 200hp
KLDE/KL03 2.5L usdm milennia(ze heads,curved neck ze intake, de cams, 9.5:1 compression) 174hp
KFZE=jdm 2.0L(k8 heads, ze cams,ze intake,10:1 compression) 170hp
K8=usdm mx3 gs 1.8L(k8 heads, k8 cams,k8 intake, 9.2:1 compression) 132hp
chris, id suggest picking up a milennia motor like i did.Its not to far from a full ze, plus i picked mine up for $116 at a pick and pull.You already know my stance on which direction you should go, ive been trying to sway you for a couple years now.Not to be a dick, but im sick of people that try and compare an n/a v6 to the boosted bp.Youll make more power, with less effort with the v6, and youll be guaranteed to make more torque.You show me a bp that makes 298whp and over 300wtq at a whopping 8psi.Not to mention, youll never be able to make a n/a bp sound mean.
Originally posted by bpt323 View Postive seen 2 millenia KLs that were not KL31 heads. just keep ur eye out you'll see what i mean
USDM Millenia motor: Millenia KL47 heads, IM, TB, 9:5:1comp /w KL01
DE CAMS!!!!!!
JDM Millenia (curve neck) motor: KLZE KL31-1a1 heads, curve neck ZE IM, 9:5:1 usdm pistions, and guess what still KL01 DE usdm CAMS!!!!!!!!
JDM MX6 motor (straight neck) : KLZE KL31-1a1 heads, Straight ZE IM, High Comp pistions, And True KLZE KL31-101 High lift CAMS!!!!!
SO this means only the straight neck ZE Is a "TRUE" KLZE The curve neck one is just a USDM Millenia motor /w a slightly better IM thats it!!!
whats this KLG4 you speak of?? any external links on this???---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
crap, i've been saying kl08
me = to high, or not high enough. i knew it was KL0_
JACK.-Jack
The KLG4 Is a KL Motor that comes in the 98-02 usdm 626's It is far better design then even the klze, as I stated above. Well only thing it lacks is the high compression. coilpacks, solid lifters, better IM than even the ZE and lighter forged crank I mean come on just far more advanced and loves boost!!!
Theres a guy on PT making 317whp on 8psi on a Stock KLg4!
Originally posted by mazdamx3freak View PostThe KLG4 Is a KL Motor that comes in the 98-02 usdm 626's It is far better design then even the klze, as I stated above. Well only thing it lacks is the high compression. coilpacks, solid lifters, better IM than even the ZE and lighter forged crank I mean come on just far more advanced and loves boost!!!
i know what of the sean/shaun/shawn 's down here has one in a red probe"Discontent is the first necessity of progress."
quite informative, how do the KLG4 heads flow VS kl31 heads? or are they the same? what about cam specs?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
