i had a 91 escort that i converted over to a gt 1.8l dohc manual 5 spd car. the shell is the lx style but its basically now a gt model. ive rebuilt the trans, and the bp motor is the short nose crank style. now thats outta the way, here my questions-
my goal with the car is 300 whp, boosted. while streetable. i want to plant a GTR motor in it from a 323 but as time passes on as i save up money for the turbo build/swap im coming to realize i might not be able to get a gtr motor. sooo.... whats my best options either build my bp05 up to a gtr or get a gtr by luck? ( i already know for 300whp the gtr would need to be build a lil more and my fuel system moded and correct me if im wrong but the gtr computer will need to be upgraded to a standalone system ?right?) suggestions on the best overall fuel setup as in injectors, rail, pumps are appreciated.
i just need advice &/or suggestions as to what it would cost me if i build my stock motor and the best overall choices i have for stuff like cams, pistons, rods, manifolds, etc. [at the most to get the motor to either as good as the gtr spec or a lil better, but to reliably handle 300whp]. this would be my first turbo motor build, so im kinda lost on the whole thing. i know i want to run a vj-23 turbo with a aftermarket turbo mani[if available]. the only plus i can think of if i go this route is that i dont have to redo a harness swap, and i dont have to worry about if i find a gtr motor.
but am i just spazzing about the availabilty of a gtr motor? i know that at some online stores that motor would run me $3000-$5000. with everything i would need too. it seems like the cheaper route to me even if i build the bottom end up more and throw me rings, gaskets and bearings at it.
i dont want to spend more than $9000 on the build. nor to i want to sit on my butt for a year waiting on a motor either. one thing i know ill want to change is the gearing on my trans. as far as i know is that the only gear i can swap is 5th making is longer outta the awd trans.
any replys are much, much appreicated.
