1500 rpm power band ??? that was my white wagon ..... was on 24psi by 3500 i was running a gt 3076r with a .63 t3 houseing......... and yes i made the adaptor plate for fe3 to e series but it is not to run 4x4 the fe3 is way to wide in the bottem of the block and it hangs way to low to cut the sump out to make clearance for a transfer ........ its hard to understand its like you can sit the block with a crank in it on the ground with no sump and the crank wont touch the ground.......
How To: Toyota E153 transmission conversion
i still dont know how you spool'd so fast ben. mine doesnt' spool for ****.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Can someone kindly email me the CAD drawing for the plate so I can look for someone who can fabricate it?
My email is afzam.sutera@gmail.com
Thank you...
I recently purchase a 1988 323 gtx. It wasn't running when i purchased it and now fixed it.
So basically what i want to do is swap a fs20det from a mazdaspeed protege into the gtx.
1. From what i remember somebody swap a 323 4 door with a klde or ze meaning i should be able to swap the mazdaspeed protege engine as a front wheel drive since the klde or ze swaps into a mazdaspeed protege.
2. I also remember reading that mazdaspeed protege fs20det can possibly combined with a jdm celica awd trans. My plan is to do a haltech powered fs20det forged engine awd 323.
Basically im looking for a trans i can use with the fs20det and keep the car awd.
I have a lot of these part currently forging and building an fs20det already have a haltech platinum 1000... Just need a awd trans to start the processMAZDASPEED PROTEGE BUILD
http://www.mazdas247.com/forum/showt...ebuild-Round-3
^ who the F is this jokester???---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Post^ who the F is this jokester???
my current project
Hello everybody raising from the dead is my grey msp that has been sitting for the past 9 month not moved or wash once since my rod bearings gave out finally pulled out the motor. Ive had a spare engine waiting a 52k clean long block long before the engine threw a rod. This is the third time its...
my gtx
So I'm new to the world of the 323 gtx although I've had a couple mazdas. I picked this car up a couple days ago car seems awesome has a lot of really nice mods Here's the car pretty clean minus the roof but i will be removing the previous owner's work he did and install a Manuel moon roof or...
most of the info I'm stating in my post are things i found on google and currently looking threw peoples builds or how to write up since i started using this thread searching for info. Your help THANKS BRALast edited by fuadmsp; 09-02-2014, 02:40 AM.MAZDASPEED PROTEGE BUILD
Im going to start looking for the gt4 trans im figuring i might need an adapter plate like the fe3 engine to run the gt4 transMAZDASPEED PROTEGE BUILD
^Well, yeah, and you'll almost be certainly be fabbing it yourself...'90 AWD Protege, full GTR drivetrain swap, ~320 whp daily driver, RIP, and
Where is a good place to look for a clean trans im starting with the toyota celica forums and researching more about the transMAZDASPEED PROTEGE BUILD
fuadmsp- If you can find someone to make an adapter plate for the FS motor to a Toyota transmission please count me in.
i support your search---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postfuadmsp- If you can find someone to make an adapter plate for the FS motor to a Toyota transmission please count me in.
i support your searchMAZDASPEED PROTEGE BUILD
