Hey guys Jus wondering If anyone Might be able to help me with some issues I'm having with my car...
Its a 1990 Ford Festiva that I have put a BPT in to..
I am looking here for help because I figured If anyone has had a problem with thier BPT's doing the same thing they might be able to let me know what it was and how they fixed it so here it goes!
I've been working on this for awhile now and finally got the car to the point where I'm ready to hear it roar..
but...
its not...
Here's a breif explenation of what is going on..
-I turn the Key to start, engine turns over and ever now and then it hick ups,
- Then if i continue to hold it turning it over it will catch and rev to 2500-3000 RPM
- Then.. dies...
It sounds like it wants to stay running but instead it cuts out...
Here's a bit about what parts I am using and what work I have done to try and sort this out
-Engine is a BPT from Jpan land
-Have Bpt ECU plugged in (ECU code BP26)
-Added 4th wire from Disty, to pin 2G at ecu
-TPS is a 4 wire, ran 5 volt constant from air flow meter to light green/red wire, yellow/black wire to red wire on tps plug, yellow wire to light green/white wire?)i think its white...
- moved yellow wire (for tps) from pin 2L to pin 2M at ecu plug
I can't remember what else I did that might effect I think that it
If anyone can shed some light on what could be the problem I would really appreciate it!
Thanks in advance,
but...
its not...
- Then.. dies...
Thanks in advance,
