As far as this hybrid goes what are the factors that make it better? A higher compression ratio, or lower compression ratio? And its the KLDE block with KLZE cylinder heads?
KLDE KLZE hybrid
i wouldnt waste the time on a DE block/ZE heads hybrid. even after its all put together, you will still have less power than a stock ZE because you will still have the 9.2:1 pistons in the DE.
'88 323 sedan, K-swapped..
Originally posted by DeeAOne View Posti wouldnt waste the time on a DE block/ZE heads hybrid. even after its all put together, you will still have less power than a stock ZE because you will still have the 9.2:1 pistons in the DE.Cincinnati, ohio Bengals for life
"Who Dey"
its not really an issue even with the higher compression. there's tons of people with boosted ze's on pt. it just means a half assed tune wont hack it. but with a decent tune, you have no worries.
and the best KL would def be a hybrid. no ZE ever came with the lighter KLG4 crank. and that alone is one of the best things to start a KL build on.~PaTricK~
-Current car's-
What are you driving?
Originally posted by bomdoutscort View PostI'm pretty sure thats the purpose so when you boost it its not running the high klze compression.
i'd go for a KLG4 if you can, like monoxide said there's lots of updated parts in those engines, crank, heads, intake manifold, solid lifters...ect.-Jack
ya idk if the 98+ 626 had wiring issues, but you'd use your ODB1 harness, ecu, disti, and maf on the klg4 engine.-Jack
klg4 only came in the 98+ 626's. didnt come in any other car. ive never heard of any wiring or ecu issues on the forums. but its not like you would be using there ecu or wiring. most would be using the mx3 or probe set up. i personally wouldnt go through the work of doing a swap, and then making it a problematic ODB2 set up anyways.~PaTricK~
-Current car's-
