So I need to know what it would take to swap it the other way around. 5spd to auto. Basically what electrical did you have to rework/repin, axles different? I think so. Ecu swap? Basically tell me what you took out to convert to a 5 spd.
ok auto to 5spd swap guys.....
Originally posted by jay.....they totally underestimated the number of gearheads such as myself that have families but refuse to grow the hell up and stop playing with cars, or that otherwise see the utility of having 4 doors. Obviously I ain't alone, as there are a helluva lotta sti and evo here. Bueler? Beuler? Mazda? Mazda?Tags: None
Originally posted by Turpro View PostSo I need to know what it would take to swap it the other way around. 5spd to auto. Basically what electrical did you have to rework/repin, axles different? I think so. Ecu swap? Basically tell me what you took out to convert to a 5 spd.
Taking out and swapping the peddles around and stuff is pretty straight forward... Same with the shifters...
yea, pedal assembly and shifter swap isn't a big deal.
Neither is the harness swap if you've done it before, and I'm pretty sure you have, haven't you Chris??
As for axles, it's the left axle that is different, apparently the jackshaft and right axle are the same MTX-ATX, but I might be wrong...lol-Jack
1990 Protege 4WD
1 3 5
2 4 R
I think there is a separate TCU up to 92 or so. I know there is a crossover point where the tranny is controlled through the ECU rather than a separate TCU. So yes, all 4wd's have a TCU if Auto. I think you can use the newer setup even in an older car as long as all the components match...Current:
68 Torino GT Fastback
86 MR2
91 F150
94 Escort Wagon BP swap
99 Escort Wagon BP swap
00 Miata LS
08 Arrow AX8
14 Mazda5
