Hello.
I have a BP swapped mazda practica, and I am running with the z5's transmission. It has a shorter setting than the lantis transmissions, but I believe it still is too long for a N/A car. A friend of mine swapped a BP engine into his 121, and he is using the 121's own transmission. There are some issues of course, like the 121's transmission is cable operated and mine is hydraulic, and there is the axle problems.
My question is, what is the most compatible transmission for my car? Will the 121 transmission work on mine somehow? Or do you guys know how to shorten the gear ratios?
My car's pics and some specs are in the following link:
http://www.wihandyman.com/forum/show...hp?54816-Hello.
Thank you all.
Thank you all.
