Pashka, the oem awd rear subframe is not a direct bolt on to the 2wd chassis and vice versa. So the subframe mounts have to be built specifically for the chassis you want to use. Maybe this will clear up some confusion?
JP Motorsports BG/BF/GT4 Rear subframe production and discussion.
Also if I'm not mistaken, the rear AWD BF subframe.... Not the links, just the subframe itself.... Is the same as a BG AWD subframe
1988 323 GT - B6T Powered
Originally posted by Damkid View PostAlso if I'm not mistaken, the rear AWD BF subframe.... Not the links, just the subframe itself.... Is the same as a BG AWD subframe
Kaleo is correct.Ian Boyd- Bellingham, WA (click vehicle to view)
1988 BF GTX
1990 x2 BG AWD Protege
1991 Escort GT- SOLD
2005 Corolla
Wow. So the mounting holes for the subframe are different that is what I am hearing correct? I figured lateral links knuckle assembly etc etc would be different but the mounting to? That's odd why would the put the chassis under the same code then? So is it the BG awd has the total mounting set-up as the BF? If there is a sticky somewhere on this please point me in the right direction. Don't want to be trying to give people wrong information.Not What you build, But HOW.
Completely different. The floor of the cars are significantly different. There are Factory service manuals out there that detail everything. Bg awd and Bf awd are similar in their subframes. The bf fwd may also be very similar to the bg fwd subframe.
The bg code is actually an abbreviation of the complete chassies code. For instance the gtr chassies code is BG8Z and the gtx sedan is BG8R. There are many others too.Ian Boyd- Bellingham, WA (click vehicle to view)
1988 BF GTX
2005 Corolla
Hey guys-just checking in again! I had about 12 weeks of racecar builds that we knocked out in 6 or so...I've got a couple of weeks free to work on these---going to try an finish a couple units---they're mostly all done except the mounting legs/swaybar mounts...I should have Ian's 4WD unit/legs on pretty quick and then we can figure out swaybar options for folks..sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
All the units---both 2WD and AWD are done except for the legs/mounting points. Ian called me over the weekend and is sending back the original piece---I think I'm going to grab an oem unit as well and re-jig it with the design/mounting point change to be safe. Your particular unit has to have the pivots redone as you wanted to be different (!) and have oem mounting lateral arms...sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
THis is all looking pretty good Jim! Just wanted to check in and let you know i didnt end up going to Los Angeles for work after all, so I havent been in your neck of the woods to further some of the things we had talked about. Im looking forward to getting my hands on a new subframe with the revisions and putting that bad boy under my car!
Originally posted by AWDXavier View PostTHis is all looking pretty good Jim! Just wanted to check in and let you know i didnt end up going to Los Angeles for work after all, so I havent been in your neck of the woods to further some of the things we had talked about. Im looking forward to getting my hands on a new subframe with the revisions and putting that bad boy under my car!sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
Just checking in-Ian was sending back the prototype rear 4WD subframe and hopefully an OEM unit as I need to rejig it with changes---Ian were you able to get these in the mail by chance? That's all I need to finish the units up!!sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
Hey in case Ian's gone for work or something does anyone else have access to an OEM 4WD rear subframe? I'll gladly pay shipping both ways to "borrow" it for a bit! My window here is going away as I've got a ton of motorsports stuff coming up soon...sigpicwww.piercemotorsports.com www.piercemotorsport.com Like us on facebook http://www.facebook.com/home.php#!/p...91292610897146
