I should post my recent map - there are no signs of detonation and the power delivery is very smooth on 94 octane. I am nowhere near 20 degrees advance at 15psi however - being that high resulted in some signs of detonation on the sparkplugs as noted above.
Megasquirt Ignition Advance Maps
The dyno day was great. I got some nice results on other cars, but didn't have time to get my own car on there. I tuned from 9:30 to 6:45 with pretty much no lunch break.
Since it was so popular, I already have enough people for the next one. If Lex gets off his ass and gets his engine done, we can both tune the cars and see how they are. I have changed my timing a bit and run more advanced at 18PSI than I am at 10PSI. For some reason at around 10-14PSI and 4500RPM, i can't run too much advanced or it will ping like crazy. That is around maximum torque area as well which makes me think that it might be something to do with coils or plugs. I do have race plugs gapped to 0.028 so it is definitely not blowing the spark out. Only dyno will tell.
Lex hurry up and finish that engine.Omid
1990 Mazda Protege GTR
1991 Ford Escort GTR (GT2876)
1985 Mazda RX-7 GT-1 Race Car (13B PP)
Originally posted by bcrx7 View PostLex hurry up and finish that engine.
Yeah!!!... hurry up and get those rods so I can put your bottom end together!
Well, after you fix my MS BP MX-3 first...
Member of MX-3.com
"Do it ONCE, do it RIGHT!"
soooooooooooooo........
anyone have some new ignition maps i can try out? :/Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
I think jacobs timing map is just fine, you guys are running too little timing. I got tuned out to 15 degrees at full boost and i know i could of gone up still quite a bit. You have to keep in mind, that n/a bp's at 10degrees of base timing would be at 33degrees of timing at full load. So for you n/a T guys running piggybacks...you are up there in the timing. As soon as i finish my new car i will up timing and see what happens, Probably cap off at like 20degrees.
Need Vehicle Graphics, Decals, Headlight/Tail light tint? Visit http://www.graphxsigns.net or PM me!
If setting your timing on a dyno, log to see where you start not making power anymore and then back off a degree or 2 because the car is under heavier load on the road than the dyno. If you have access to a dyno that can brake the car at a certain RPM and certain load with real time view of torque, that would be the ideal way to tune. Dyno pulls that just run through to redline are good to see max power but not good for tuning - you are touching only on a few points of the operational engine map.
Originally posted by b-potent View PostYou have to keep in mind, that n/a bp's at 10degrees of base timing would be at 33degrees of timing at full load. So for you n/a T guys running piggybacks...you are up there in the timing.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
heh, i ran my motor for 2 years on piggybacks and it ran just fine which is why i think timing for sure should be over 20 degrees.
werd---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
pumping an old thread
at 18-22psi here is what i'm running for ignition advance. 500 rpm increments from 3500-6500. seems to be working well, just very minor "salt and pepper" on the plugs.
16 14 14 14.5 15.3 16.1 16.1
stock gtr compression (8.2:1) with low-mid 11's AFREscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
ive been told it needs to be dropped a little at peak torque and then brought up as RPM increases.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by dok33 View PostHere's what we're running on our turboed BP Festiva, stock Escort GT motor with a DSM T25, currently at 8psi:
Doing some more tuning tonight, we'll see how it works! Any input would be greatly appreciated!
Don't be afraid to also push your timing in the 1500 and 2000 RPM sections into the 30s.
