Yes I know its not the conventional setup for the BP, unless its a miata. Basically I have no clue how to tune the car when I go with the supercharger. is there a purely mechanical way that I can go, coupled with larger injectors and the RX7 VAF? I ask about the mechanical because electronics and I do not get along very well, I believe they have a problem with me
Going Supercharged
a GTX ecu/injectors/rx7 vaf would probably work pretty well with a superchargerEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
no you will just need GTX injectors.
you're mixing things up with the GTR ecu/injectors (which are low impedance)Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
pretty sure they would be way too small, and i think they are also side-feed (not sure)
you need a 360cc injector or something pretty closeEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
mx6/626/probe 2.2 turbo injectors can be used if you wire in the correct plugsEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
you can use rx7 injectors (or my GTR injectors) but you will need a SAFC or something similar to tune themEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
