I am running the gtx ecu on my escort. If i remember correctly the gtx use's a one wire o2 and my car use's a 4 wire o2. So question is will the 4 wire one still work right or should I set itup for a one wire?
o2 sensor on gtx ecu
gtx came with a 3 wire heated..
your 4 wire should still work right, as long as you use the 95 harness.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
