can i do the same with the lm-1
Widebands
86 626 5dr- f2t swap, holset, and love of my life
89 323 3dr- saving gas stock
91 323 3dr- full race coming soon
92 protege- test mule for now
87 supra- sick not dead, i need more boost
96 740il- smoked out on stgd 20s, no chrome
and so many other cars
The way to tell the difference between an automotive enthusiast and a
person who only loves what they drive is simple. The use of the word RICER!!!
i believe the LM-1 is just an LC-1 with a gauge included in the kit? i could be wrongEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
I know it is kind of back from the dead, I got an LC1 with DB gauge.
Funny things there are instructions for the install of the sensor calibration, but nothing on hooking up the gauge.
The gauge has four wires: red, yellow, black and white.
From what I understand the yellow one is analog output signal.
Black which is shared ground (recommended by Innovate)
I get stuck with the red and white, the first one must be 12v source and white maybe night lights but the manual does not specify.
Here is a link from innovate, or I found the wrong manual or it is obsolete as the cables shown are blue and purple.
By the way, I did a few searches and many were random or did not cover anything about digital gauge, at least the ones I searched for using wideband, LC1, install, installation, but no joy!
Originally posted by psiturbo View PostI know it is kind of back from the dead, I got an LC1 with DB gauge.
By the way, I did a few searches and many were random or did not cover anything about digital gauge, at least the ones I searched for using wideband, LC1, install, installation, but no joy!-Mike
06 Taurus SEL/92 Escort GT/93 RX7 R1
Look on page 2 of that DB manual. You must have the gauge that has the "Innovate Motorsports" logo on the face instead of the one that says "Wide-band Air/Fuel".
--Ferdi
Edit: bmikedaman beat me to it.If you can't differentiate between brake and break, you should go back to school
Thanks for the response, I managed to send it back to warranty and just finished installing it yesterday.
So far so good, seems to be working pretty well. The Digital gauge is one cool device, although at night I wish I could dim it a little more. Right now it dims when I turn on the lights, but wish it was more low key.
Having a gauge moving numbers all the time drives me crazy, I guess its a matter of getting used to.
At WOT it stays at a steady 12 reading, sometimes when I let go off the gas it will momentarily display 22 briefly and then continue reading as usual. Saw a few videos on youtube and seems to be normal, even AEM shows similar symptoms.
