in all honesty its not really worth revving past that anyway, the efficiency of the vj20 drops off so much
GTX ECU and compression ratio
So, what is the highest compression ratio that you can safely go to with the stock BP ecu (as found on a '91 Protege LX)? I don't want to go crazy high. Is 10:1 safe?
Am I going to end up like this guy? --->
its not a good idea to blame the compression ratio for that damage.
chances are too poor of conditions & high EGT's as a lack of tuning.
Matt fulgham is running 12+ compression so i think you'll be safe---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by bpt323 View Postits not a good idea to blame the compression ratio for that damage.
Yes, there are so many factors that could have led to that damage.
I personally run 9:1 non-forged miata pistons with a slightly shaved head (to straighten it) with zero issues. I have bp26 injectors and ecu and a probe fmic with a turbo rx7 afm. Only issues I've ever had was with lower octane (91) and boosting very near 15 psi.
I need/want a bigger turbo as the vj20 is a dinky little turbo like everyone says and it dramaticly drops off far before red line, instantaneous spoolup (2500rpm) is annoying too.
3 grand spoolup is nice put a VF8/10/12 in there---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
