well heres the deal now, i had the power cable grounded and then the battery which kept shorting me out sooo then i ran it to the block so i didnt have soo much current going through the chassis, now to figure out where the 12volt source is and get the ms turning on when the key is at the "on" position. i need to borrow a multimeter to see if this white/red is giving the 12 volts it should be.
Megasquirt Blowing Engine Fuse
