"im going to start off with i dont know much about MS im just trying to learn it, so im sorry if i come off a lil dumb."
Well i just put J.R. plug and play M.S. 1 in my escort and loaded the maps he ran with another car with the same set up. well let me back up.......
i have a 92 escort gt w/ gtx swap im trying to run ms1 without the tps 4 now. i have a wideband o2 and the plug and play harness J.R. made up for me. im using the stock temp sen. and the gm(i think) intake temp sen. im using the stock gt coil and dist. the ms1 has a 4 bar map.
ok well i loaded the preset maps onto the ms and made sure all the setting were right and that the gauges were working. i try to start it and it starts for about 4sec and dies. thats about all i can gte out of it. the trigger angle is set and the timing is right. im getting spark out of all 4 wires/plugs. i can smell the fuel after i crank on it a few times. im just so lost with this whole thing and thinking about just givin in and getting rid of my escort..........
i can email you my setting if you want to check them out. one of my friends messed around with it a lil but nothing.
