they dont look to be cracked just hav black tips
fried ecu
yea im noticing that now i see another like that, im gonna say your gonna have to plug it back in and see what input/output is missing there something is missing a signal somewhere.... also in shipping its possible it may have got knocked around and a solder joint came loose... i fix car audio amplifiers, and most i open up have some sort of tell to them... like black somewhere from smoke....Last edited by yunvmyegt; 12-08-2008, 08:39 PM.92 protege lx-
94 protege lx-
Originally posted by yunvmyegt View Postyea im noticing that now i see another like that, im gonna say your gonna have to plug it back in and see what input/output is missing there something is missing a signal somewhere.... also in shipping its possible it may have got knocked around and a solder joint came loose... i fix car audio amplifiers, and most i open up have some sort of tell to them... like black somewhere from smoke....
if it wont start with the gtx ecu and start with the stock ecu something with the gtx ecu is wrong because it is plug n play
na i get that, but i go past the oh its bad and find whats actually bad... but im more looking at what in the board is the problem. maybe the injectors arent firing? just an example, but if someone tried to run low ohm injectors on it and overloaded the injector circuit, this is the stuff i have to fix on amps, i mean if by chance it is just that. replace the 2/4 fets that fire them, or if they dont have the signal from the control board, or how ever its controled in the ecu trace it back. if the numbers arent wet sanded off the parts like alot of stuff i play with, parts should be relatively ez to find.... on a side note if you dont wanna mess with it, what would you want for it i may wanna play with it....Last edited by yunvmyegt; 12-09-2008, 05:39 PM.92 protege lx-
94 protege lx-
wanna sell that GTX ecu for cheap?"Discontent is the first necessity of progress."
