so on a speed density car, would the barometric pressure make a difference? on a local forum a guy asked this question. i tried to explain but what i typed out just sounded stupid lol. say your running a standalone on a speed density car. what would be the need for barometric correction. someone give me a good answer because what i tried explaning to the guy just sounded dumb.
barometric pressure
not a tech article.Beater=/= Sleeper
The way I understand it is that in a Speed Density system the computer calculates the mass of the incoming air based upon its temperature, the manifold pressure and the engine speed. Basicly the standalone uses the MAP sensor, IAT sensor and the engines RPM to then calculate the mass of the air by using the universal gas law. So if the pressure in the manifold isnt really what the MAP sensor thinks it is the computer will miscalculate. Basicly the MAP sensor calculates the difference in the pressure between the outside atmosphere and the vacuum level inside the intake manifold.
Lex should chime in and explain it better and more accurate....BPT Power....Drop a gear and disappear.sigpic
